- Pine Beach, NJ
for Metal Finishing since 1989
Is Nickel Strike allowed before Cadmium plating heat treated bearing steel?
Q. Have problems with adhesion of cadmium plating over 52100 steel (1% C, 1.5% Cr). Advice from experts in the field suggest a Nickel strike which yields positive results. Because of the Cr content, can we classify the 52100 as being corrosion resistant and/or passive whereby Nickel striking would be permissible IAW AMS2400Y and AMS2401? Have run across articles stating that 52100 steel is corrosion resistant.
Marc A Pelissier- Springfield Massachusetts
December 15, 2020
A. Marc
AMS2400Y refers to 'corrosion-resistant steel or similarly passive materials' in allowing a nickel strike.
Depending on who you talk to, 'corrosion resistant' steel has approximately 10.5% or approximately 11% chromium content.
At 1.5% chromium, it might be an uphill battle trying to convince someone that 521200 was a corrosion resistant steel.
January 11, 2021
? Marc,
Please detail your preparation steps: solutions, concentrations, temperature, time, current/no current, polarity, etc.
Alex
- Lod, Israel
January 14, 2021
