Plating onto tin substrate
Q. I have started casting small medallions using lead-free solder (over 99.6% Sn). Sometimes I also mix in 20% bismuth to get a better cast. Now I'm interested in plating them with copper, and possibly gold.
Will copper take to tin? Or should I start with nickel or zinc or something, then copper as the final layer? And the same question for gold really.
Mallory Nichols
- Burnley, England
July 6, 2020
A. Hi Mallory. I think you would be able to do such a process, or have it done, but that the tin & copper or tin & gold, will diffuse into each other too readily. I think you'd probably be better off doing nickel plating as a diffusion barrier first before the copper or the gold. Although I've heard of some adhesion issues when plating onto tin, I would expect that medallions would not be soldered, or exposed to high temperatures or stresses, such that in your case adhesion issues will probably not be a significant problem.
pic of Ted Mooney
July 2020
