Lime-A-Way took away the shine on my stainless steel fridge door - how can I fix it?
Q. I did the same thing: Lime-A-Way down front of my stainless steel fridge.
Barbara Campbell- Staunton Virginia
October 22, 2022
privately respond
to this RFQ ⇧
Ed. note: As always, gentle readers: technical replies in public and commercial replies in private please (huh? why?)
Q. Thanks for reading. While cleaning the water/ice dispensing portion of the fridge with Lime A-way, she failed to recognize that some of it had dripped off both edges, running the entire three feet down the front of the door to the bottom of the fridge. The fridge is a Whirlpool Stainless steel; Needless to say, two distinct lines running 3 ft each on the same door doesn't look great. Could somebody please give me some step by steps on how to repair this without settling for replacing the door. Thanks again.
Matthew C [last name deleted for privacy by Editor]hobbyist - O'Fallon, Illinois
Q. I used Lime-Away on my fridge water/ice dispenser and it dripped down the front and left drip stains on my stainless steel. Can I use Car Polish to get rid of it?
Vanessa Gionis- Sugar Land, Texas, USA
June 30, 2010
A. Vanessa, harsh chemicals like C-L-R should never be used on stainless steel as they will compromise the chromium barrier of stainless and result in staining.
Scratch-B-Gone will restore the finish of damaged stainless.
Best
Barry Feinman
BarrysRestoreItAll
Carlsbad, California
Q. I have tried 5 popular stainless steel cleaners, Lime-A-Way, fantastic, vinegar water, and vinegar/baking soda mix for my drip stains from the ice maker on my new stainless steel fridge . . . nothing has worked. Would silver polish be an option? Very stubborn . . . not even a little better after spending so much on these possible solutions. Thanks for any thoughts.
Celeste Fasone- Woodland Park, New Jersey, USA
March 17, 2013
A. For water stains on the stainless fridge, use WD-40 [on eBay or Amazon (adv.)] . Yep ... I tried EVERYTHING and this works great. I now clean all stainless steel products with WD40.
Billie Dias- Kapaa, Hawaii
Q. I read on Pinterest that I could rub a cut open lemon to erase water streaks on my stainless steel. I did this a few times and it worked great. I rubbed the lemon on the areas and promptly wiped off the appliances with warm soapy water. It shined like new.
Recently, I had several water lines running down my refrigerator door. I used my lemon technique and it didn't come off completely, only took some of it away. I thought I should let the lemon sit on the fridge a little longer ... got distracted, FORGOT about it and noticed it dried on the spots the next day. When I cleaned with warm soapy water, the stainless steel now appears as one big light circle on the door (lighter than the original stainless steel color). The fridge is only a year or so old. Have I ruined it? Is there any way to clean it with something that will make the color look even throughout? I want it to appear as dark as the rest of the stainless steel. HELP! Can't afford to buy a whole new fridge (Whirlpool Gold). I have a photo but the link to send it would never open?
Rebecca Nielsen- Mechanicsville, Virginia, USA
September 22, 2014
Ed. note: We aren't seeing the problem with the link, but please e-mail the pic to mooney@finishing.com. Thanks.
A. I used Lime-Away on a refrigerator ice/water dispenser to remove built-up mineral deposits. Big mistake. Some of the Lime-Away got on the stainless steel door and permanently (I thought) discolored it with black "stains". So I did what turned out to be the "smart" thing and got on the internet ... I quickly discovered that other people had fallen victim to this same problem.
Lots of solutions were proposed, but I finally hit on using Barkeepers Friend [on
Amazon (adv.)]. Just a small amount sprinkled on a damp, soft cotton cloth, rubbing gently WITH THE GRAIN and in no time, the stains were gone! I finished up with Sprayway Stainless Steel Cleaner [linked by editor to info/product on Amazon] and the refrigerator door looked like new again! Whew!
- Frisco, Texas USA
Ed. note: This website is primarily for camaraderie and technical info exchange. For time-proven reasons, this "no registration required" website tries to avoid postings which suggest brands/suppliers/sources (why?).
But most consumers aren't chemical technicians, so when a thread is highly consumer-oriented like this one, we must bend the guidelines. So, mention products if you must, but try to restrain yourself from overly glowing praise, and no slams please :-)
Q. I used Lime-A-Way to clean the hard plastic 'container' at the bottom if my ice and water dispenser. Some of it spilled over on to the fridge door and now it's dull compared to the rest of the door/fridge. Is there any way to bring back the original shiny look? Thank you!
Norma Jarman- Corpus Christi Texas USA
June 6, 2020
