Coating irregular surfaces with thick clear plastic
Q. I want to coat a fragile piece of drift wood with clear plastic to give it strength yet preserve its beauty. I suspect I would need to significantly modify the techniques used to coat tables and bar tops with thick clear pourable plastic. Any suggestions?
Lyle Hoppie
Hobbyist - West Bloomfield, Michigan
February 10, 2016
A. Try Paraloid B 72 dissolved in acetone [on eBay or Amazon (adv.)] (20% solution); 'water glass' [on eBay or Amazon (adv.)] can be used too.
Hope it helps and good luck1
- Zagreb,Croatia
February 11, 2016
