Blister issues, salt spray failures in Plating + ED Coating Process
Q. Please clarify How to Come out From Quality issues while doing Plating + ED Coating Process , Salt Spray Failures, etc. -- mostly from blister issues.
M Sankar
- Chennai, Tamilnadu, India
December 18, 2015
A. Hi Sankar. If you take the time to write a couple of pages describing in close detail exactly what you are doing and what problems you are having, there is an excellent chance that our readers may have a couple of helpful hints.
But I think you should immediately retain a consultant experienced in these matters because to get from where you are to where you need to be will likely take many months otherwise. Best of luck.
December 2015
