Q&As since 1989
Tin Whiskers a Problem with Immersion Tin PWB Finishes?
I am researching the application of compliant pin /pressfit connectors into pwb backplanes. The backplane manufacturers recommend immersion tin as a pwb finish. What about tin whiskers. Many of the telecommunication companies are using pressfit backplanes with immersion tin pwb finish, (Lucent, Alcatel, Nortel etc). Are they not worried about long term reliability or is there something significant to electroless/immersion tin plating processes and the deposit that inhibit tin whiskers?
Shawn P. ThomasBoeing - Everett, Washington, USA
- Tin whiskers are covered at the Goddard Space Flight Center
- nepp.nasa.gov/whisker/
For ground hardware, the whisker blows open and dissipates.Usually no lasting damage is done to the hardware. In space a tin plasma forms in the area and allows a large enough current to flow that can destroy even hardened electronics.
Kirk MuellerRaytheon Systems Co. - El Segundo, California USA
I am researching the occurrence of failures in PWB assemblies that can be attributed to conductive anodic filaments (CAF) or hollow fibre migration (HFM). I am particularly interested in the possible increase risk of failure on Immersion Tin finished product.
Has anyone established a connection between specific metallic finishes and increased exposure to CAF/HFM?
This is my first excursion into the cyber world, I shall await the avalanche of collective knowledge with great interest.
-Circuit Logistics Ltd - Huntingdon, UK
The correct bismuth content in an alkaline tin bath is should inhibit tin whiskers
Derek Skaro- Blaine, Minnesota, United States
I worked in the electronics industry for several years, and the topic of tin whiskers seems to surface periodically. Extensive studies were conducted in the '80s with the conclusion that tin whiskers "grow" as a means of stress relief form the plating operation. Reflowing the tin reduces the stress, but does not entirely cure the condition. A dip coated tin has significantly less stress than an electroplated tin, but whiskers can still develop. Over-coating and encapsulation were tried, but the whiskers can break through the coatings. So, if you have a critical application, avoid tin.
David Strawser- Ramat Gan, Israel
