What to do if AMS2759 heat treat cycle was interrupted
January 27, 2015
Q. During the first run to AMS2759, the furnace lost power after 5 hours of an 8-hour cycle. I'm reading the AMS and it doesn't clearly state what to do. Do I put it back in and restart the cycle? Do I have to plate it again?
Mike Chados
Engineer - Gainesville, Florida, USA
Hi Mike!
If you're referring to AMS2759/9 baking after plating procedures, then when we've had power outages or other problems I look to the "Multistep Processes" wording in paragraph 3.3.3.6 for guidance. Certainly you still have to contact the customer/design authority for resolution, but the hardness and time working of those paragraphs give a strong indicator of the relative severity of the issue.
lee gearhart
Lee Gearhart
January 29, 2015
January 30, 2015
Q. Thanks for the input. We are manufacturing 440C parts and have been told to perform this operation as an output of passivation as we have been told passivation is a form of plating. What are your thoughts on this?
Mike Chados [returning]
A. Hi Mike. Passivation is not a form of plating. With regard to the possible hydrogen embrittlement caused by passivation, please see letter 58390, "Hydrogen embrittlement from passivation?"
January 2015
