Can a pH 1.0 buffer be made of HCl and nothing else?
Q. I have a question about buffers. I am looking to evaluate a new supplier for a pH 1.0 buffer used to calibrate a pH meter. I have found two suppliers that make it with just hydrochloric acid. Every thing I find in my reference book is that a buffer is always a two component system in this case an acid and a salt. Can you use a solution of just hydrochloric acid to calibrate a pH meter?
Linda
Linda Croft
chem lab tech - Endicott, New York
February 15, 2012
Consider it to be a standard rather than a buffer. It works without a second component mainly because it is highly ionized and quite strong. With proper use, it works well.
First of two simultaneous responses -- February 16, 2012
Every formulation I've seen includes KCl, too. I think this might contribute to a more stable probe response.
dave wichern
Dave Wichern
Second of two simultaneous responses -- February 16, 2012
February 17, 2012
Good day Linda.
You are indeed correct about two salts. For ph buffer 1.0 try 50 mls. 0.2 M potassium chloride and 134 mls. 0.2 M hydrochloric acid. Hope this helps.
Eric Bogner
- Toronto Ontario Canada
