Is There a Test to Detect Chromate (Chem Treat) on Galvanized Steel Sheet
How can I test if galvanized steel sheet has been chem treated (with chromate)? We are painting the steel and need a quick test ,if one exists. As we know paint does not properly adhere to chem treat galvanized steel. We need to test the steel and get an almost immediate response, is there a chemical that changes color when it contacts chromate or a simple test along these lines? help would be greatly appreciated.....
Adam Jackson
- fort lauderdale florida
Dear Adam
Best spot test for chromate is sym-diphenylcarbazide in acidic solution. recommend that you try a o.1% w/v solution of sym-diphenylcarbazide in industrial methyalated spirit, to which 10 % v/v acetic acid [on eBay or Amazon (adv.)] is added. Chromate should give an immediate pink color. Alternatively use the chromate detection sticks marketed by Merck an other suppliers. But be sure to acidify before use, as in neutral solution Sym diphenylcarbazide reacts with most metals to give a pink color. Regards
Tom Kinsman
- Burnley, UK
Is there a quick test I can do out in the field, on pre-galv sections to check if they are passivated ?
Barry Lyndon
Sales Engineer for MWF manufacturer - BURNLEY
March 14, 2011
Hi,
Can anyone tell me where I can buy these "Strips" to check for chromate ?
Barry Lyndon
March 14, 2011
