Basic requirements for setting up shot blasting of metal
Hi, my name is Alan Wong, live in Malaysia. I would like to seek your valuable advise of setting up a steel shot blasting plant in Malaysia for blasting I beam (40 feet) and steel Blade (8 feet by 20 feet). What are the basic machine requirements you need to purchase and the standards I need to look into. Your prompt reply is very much appreciated.
Alan Wong Kian Hwa
G.manager - Selangor, Malaysia
November 16, 2011
Your parts are pretty big and heavy, but you probably have handling equipment for these items. If you have a lot of volume, your might want to consider a pass through system with multiple heads to work all of the areas of the part on a continuous basis. On a more economical side you may want to consider building a blast room and use one person to manually apply media. Make sure you make provisions for reclaiming media.
tony kenton
AF Kenton
November 18, 2011
