- Pine Beach, NJ
for Metal Finishing since 1989
JIS Plating Spec."M-NI"
Hello, I am having a difficult time determining what exactly this finish callout is on the drawing:
FINISH:
M-NI (3 TO 5 MICROMETER) PER JIS
I have had no success on determining this callout. If anyone can help me out, I would greatly appreciate it as I have spent hours on the net looking for some help. Thanks in advance!
-VM
Mechanical Engineer - Los Angeles, California, U.S.A.
March 16, 2011
It is likely specifying some type of nickel plating, either by an electroplating process (JIS H8617) or an autocatalytic/electroless process (JIS H8645). The designation is not entirely correct-- it should be MFNi is the basis metal is iron, or MZNi if it is zinc or zinc alloy, or MBNi if it is copper or copper alloy.
Toby PadfieldAutomotive component & module supplier - Michigan, USA
March 25, 2011
