How to strip Tin Plating from Alloy 42
HOW TO REMOVE TIN COATING (GIVEN BY TIN WASH) ON BASE METAL 0.1MM THICK ALLOY 42
SUDHIR SHRINGARPURE
CONSULTANT - MUMBAI, India
March 8, 2011
There are proprietary strippers based on nitric acid or ammonium bifluoride that may work for this. It should also be possible to strip the tin electrolytically in a warm caustic solution.
Lyle Kirman
March 10, 2011
