Best method to check Zinc alloy plating thickness
Dear sir,
we have component of zinc iron and zinc nickel plated can we check the thickness of this component directly by thickness gauge like Minitest 600B or Elcometer or by distractive method by sn3 solution, or is there any separate instrument for checking zinc alloy component pl tell me which is the best way to check thickness.
Darshan
Darshan Vernekar
plating shop employee - Bangalore, Karanataka, India
February 18, 2011
The best way is by XRF or by microscopic cut section imagery.
Khozem Vahaanwala
Khozem Vahaanwala
Saify Ind
Bengaluru, Karnataka, India
saify logo
March 19, 2011
April 26, 2011
The most rapid method is the XRF. Cross sectioning takes much more time, but can be used. I'd make my own panels of known nickel in the Zinc alloy. Then, calibrate my XRF machine to assure that the result is accurate and meaningful.
Your XRF supplier may be able to sell you standards. We used to make our own. Plating with Zinc/Nickel, Stripping the coating on Steel, and stripping the coating completely. Then using an A.A., analyze for Zinc and Nickel to derive the exact percentage of each.
ed budman eb sig
Ed Budman [dec]
- Pennsylvania
