Chrome plated rod surface defects
Dear All,
I am finding difficulty in understanding the chrome rod surface defect. I checked the chrome thickness it's 50 microns. The surface is having many pin holes with rusty marks.
I don't understand what could be the root cause for this.
Could somebody help me to understand the defect caused on the piston rod surface?
Sivaraj
Sivaraj Thangaraj
Hydraulics - Sharjah, United Arab Emirates
January 19, 2011
your cleaning is not proper.
check surface of rod before plating.Do the water break test.
Muhammad Umair Khan
- Lahore, Pakistan
January 20, 2011
You may have a lot of suspended solids in the chrome tank, especially if you use agitation.
Hi,
You can use an porous pot and dummy the solution so that if it have any impurity can be removed.
Best Regards
praveen kumar
Praveen Kumar
plating process supplier
Mumbai, India
February 4, 2011
