Micro deburring and surface refinement of small HSS metal cutting tools
January 13, 2011
I'm looking for electropolishing & alternatives, for the micro deburring and surface refinement of HSS metal cutting tools (burnishing could also be of interest i.e. pre or post heat treatment).
My dilemma/requirement is that the cutting edge tool is only 0.6 mm wide (0.023 inches).
Please recommend methods/processes/services for consideration.
Nicholas Glazer
Product Engineer - Sweden
Nicholas,
I'm no expert, but this sounds like an ideal application for thermal deburring. If you google it you will find plenty of information on the subject.
Brian Terry
January 14, 2011
We have successfully deburred and polished parts in a vibratory deburring machine using dry organic abrasive media many times.
tony kenton
AF Kenton
January 21, 2011
While micro deburring may sound good, however small burrs will not be eliminated from the surface, making the cutting surface less hydrophilic. On the other hand electropolishing not only remove burrs, but in the special regimes can sharpen the cutting tools. The high-carbon stainless steel alloy can be perfectly electropolished and sharpened. See pictures attached.
56517_1
56517_2
Contact me for more information.
anna_berkovich
Anna Berkovich
Russamer Lab
Pittsburgh, Pennsylvania
russamer labs banner
January 21, 2011
