Designing a round phosphating tank of 500 cm3 capacity
Good day. I want to know some design features in producing a 500 cm cubic phosphating bath. I want the bath to be cylindrical in shape, heating temperature will be between 70 and 90 °C, source of heat will be by boiling ring.
It is a project given to me as an undergraduate student in Nigeria. My aim is to:
1. Design a laboratory phosphating bath
2. The use of the bath to phosphate metals or materials for corrosion resistance and aesthetic value.
Thanx
Peter Akorede
Student (undergraduate final project) - Alagbado, Lagos, Nigeria
December 28, 2010
Do you mean 500 cc (ml) or 500 cm diameter. If it is the first, use an 800 or 1,000 ml glass beaker [beakers on eBay or Amazon (adv.)]. You can use a larger beaker with a floating ring cover as a heat source.
