Alkaline zinc plating issues
Hello, I run a alkaline zinc line with merlin brightener, ultra pure, and starter. We use caustic soda [affil links] membrane grade and haven't added caustic soda in almost 2 months. Is this a problem and can the temperature of the solution affect the plating (low rectifier amperes?)
Jake Skinner
waste water treatment - Clinton, Iowa, United States
December 16, 2010
What you should be doing is analyzing the bath to see that the caustic soda (sodium hydroxide) content and the zinc metal content are within the suppliers parameters for a properly operating bath. The time between additions is meaningless if the bath is out of spec.
gene packman
- great neck New York
December 26, 2010
