Removing carbon layer from mild steel
⇦ (tip: readers rarely show interest in abstract questions;
actual situations usually prompt responses)
- Peretborough cambs [Peterborough UK]
February 2, 2024
A. Not knowing what these deposits are on, or how they got there, I can't hazard a guess as to whether they are carbon or not.
But there is a commercially available product called "Carbon-Off"
[on
Amazon]
. Note that it contains 40-70% methylene chloride plus some other nasty materials, so gloves [on
Amazon], goggles [on
Amazon] and excellent ventilation are required. Personally, I can't recommend spraying or aerosolizing methylene chloride, so I'd suggest the liquid version and working outside, from upwind.
I don't think bicarbonate of soda will do anything as a chemical solution. But people might have been talking about using a soda blaster [soda blaster on
Amazon]
Q. Hi you have to excuse me, not very tech savvy. I've read some of your stuff so I know you know what you are talking about. I'm trying to clean these in picture.
They're off top of cooker made of cast aluminium, and need cleaning they are black with burnt on oil splashes or carbon? Hope you can help.
Bobhope gill [returning]- Peretborough cambs [Peterborough UK]
February 3, 2024
A. Hi again. If you don't like the Carbon-Off idea, or it isn't available to you, Thread 41066 has several entries about aluminum cooktop burners. Among the suggestions were Silvo metal polish [on
Amazon] and Brillo
[on
Amazon].
But doing this manually with metal polish or a Brillo pad sounds like it might take forever. I'd suggest trying a polishing buff on a Dremel
[on
Amazon] or a Mothers powerball mini [on
Amazon]
on a low-power battery-operated drill, using a compound like Mothers Aluminum & Magnesium Polish [on
Amazon]
Q. Sir please help me to remove a hard black carbon layer from ms plate by using any alkaline based treatment.
Hemant Sharmaowner of company - Faridabad, Haryana, India
December 14, 2010
A. Dear Mr. Sharma,
You can try the following steps:
1. Hot Degreasing
2. Anodic Cleaner (I)-High Alkaline
3. Acid Pickling - HCl 40% v/v + inhibitor or and accelerator
4. Anodic Cleaner (II) - High Alkaline
5. Acid Dip
6. Next treatment.
We tested and got good result.
Try and you can see the result.
Best regards,
- Jakarta, Indonesia
January 21, 2011
A. A high pressure water jet can be very effective. Don't try it on small parts - it will throw them all over the shop.
A. Dear sir
first what kind of metal finishing you will make in the surface of this carbon steel ?
if you will make any kind of electroplating you must work in the following sequence
1- hot soak chemical degreaser
2- cold rinsing
3- hot cathodic degreaser
4- rinsing
HCl 40% by volume at room temperature
5- rinsing
6- hot anodic degreaser
7- cold rinsing
7- complete the sequence of electroplating
if you will painting it you must make the following sequence
1- hot soak or spray pre-chemical degreaser
2- hot soak or spray chemical degreaser
3- hot (50- 65 °C ) sulfuric acid 8 - 10 %
4- cold rinsing
5- cold rinsing
6- alkaline passivation
7 hot dryer
best regards
metal finishing - Egypt
February 17, 2011
A. Lots of ways and options. Put a picture of the part on to enable select the right one for you.
Khozem Vahaanwala
Saify Ind
Bengaluru, Karnataka, India
March 19, 2011
A. In addition to one of the pre-treatment sequences already mentioned, the use of an ultrasonic transducer in the first rinse after the sequence should help to remove any residue that is still on the steel.
Lyle Kirmanconsultant - Cleveland Heights, Ohio
March 23, 2011
A. The advice given is good. Just one final comment. Are you sure it is carbon? It could very well be iron oxide.
March 29, 2011
