Electroless nickel plating of ceramic powders
I am, Mahesh Kumar, doing PhD on Composites fabricated by Powder Metallurgy route in Cardiff University, U.K.
To avoid the diffusion of atoms across the powder interface during processing, I am planning to coat the powders with Ni by electroless plating method.
This is to enquire whether it is possible to coat ceramic powders (particle size 3-5 microns) like SiC, TiC, Al2O3 with Ni by electroless method?
Mahesh
Mahesh Kumar Mani
student - Cardiff, United Kingdom
November 18, 2010
Mahesh, I am working on this same problem. I would like to use electroless nickel to coat ZrO2 (zirconia) round particles approximately 0.5 mm in diameter. It should be possible. I remember when I was a student some years ago I was putting electroless nickel coatings on epoxy and it worked well. Let's keep in touch and see if we can come up with something.
-Lucien
Lucien Hehn
nov - Spring, Texas, USA
November 23, 2010
Dear Mr. Hehn,
Thank you for your reply.
I will try to coat the powders by following the procedure mentioned in literatures. I will intimate you the outcome of my experiments.
Mahesh
Mahesh Kumar Mani
November 29, 2010
Years ago you could buy EN coated diamond particles. Research expired patents or find a company that is qualified and have them do it or buy their technology.
