Black spots in cyanide copper plating
Q. On a copper-plated MS Screw, I am facing black marks. To ensure a lengthy shelf life, we need a suitable remedy for the black stains.
Amit Kadamemployee - Pune, India
May 15, 2023
by N. Kanani on
AbeBooks or
A. Hi Amit. Copper is not a tarnish-resistant surface. You can try a dip in a proprietary benzotriazole
[on
Amazon (adv.)]
copper preservative if you feel the problem is simply the insufficient shelf life of the copper.
But sulfur
[affil links] in the environment will cause blackening of copper. And as mentioned on this page already, cyanide copper will often get blackish bleed-out stains.
Please send pics to mooney@finishing.com for posting here, and give us at least your general treatment cycle. Thanks.
Q. We're into cyanide copper plating, we are facing a problem as mentioned below:-
After plating MS screws in cyanide copper plating by barrel method, after some time on the threaded portion we are finding some black dots on the plated surface. what could be the reason
warm regards,
Thyagaraj
plating shop employee - Bangalore, Karnataka, INDIA
July 1, 2010
A. Hi, V. When cyanide-based plating exhibits dark spots or dark areas after some time, it is usually "cyanide bleedout". The way to solve it is better rinsing: possibly alternating hold and cold rinses, or an ultrasonic generator in a rinse tank, or a neutralizing agent like sodium metabisulfite or at least sodium bicarbonate, possibly a final D.I. rinse. Good luck.
