Salt water dip test for rusting
SALT SPRAY
TEST CHAMBERS
Q. I need to test for box pin rusting, How can I validate this with respect to any standard like ISO, ATMS, MIL, etc
Please give your input for validation method (like Salt water dip test, salt powder, etc.) with respect to standard.
Purushothaman Purushothaman
employee in HCl - Ambattur, Tamil Nadu & India
June 2, 2010
A. Hi, Purushothaman. The single most common way to test is probably ASTM B117 salt spray testing. But if you have no salt fog test equipment, the easiest and least expensive standardized test to implement may be the CAMRI test described in www.zinc-diecasting.info/zdc-PDF/SurfaceFinishes.pdf
Luck and Regards,
[Ed. update: The above link has broken. Thankfully, The Internet Archive preserved a copy smiley face
These days information often appears on the internet, then disappears forever. If that frightens or concerns you please consider a donation to The Internet Archive.
