Is sulfuric acid pickling okay for hardened parts
I'm doing zinc plating with sulfuric acid pickling and cathodic cleaning in pretreatment line. We found difficulty on doing hardened part, because after several days sometimes white rust appears all over the part, meanwhile other parts still OK. Can sulfuric acid cause this problem? Can you explain to me how it works? For your information our plating is alkaline type. And our flow process for hardened part is: pickling (H2SO4: 100 cc/L) 2 min, anodic clean 3 amp/dm2 3 min, cathodic cleaning (H2SO4 100 cc/L) 2 Amp/dm2 4 min, anodic clean 3 amp/dm2 3 min, activation (HCl 50 cc/L) 1 min, than go through to plating. Thanks for all
rusty component
Joko Prasetyo Yuniartato
plating shop employee - Bekasi, West Java, Indonesia
May 27, 2010
Gentleman,
I feel Anodic cleaning in Alkaline potassium permanganate [on eBay or Amazon (adv.)] is suitable followed by mild acid dip in HCl is sufficient to have better coverage instead of having anodic and cathodic sulfuric acid cleaning.
Another option is, you can use caustic soda [affil links] and sodium cyanide mixture with PR cleaning also suitable for Hardened parts.
All the best
Shankaranarayanan N
SHANKARANARAYANAN NARAYANASWAMY
- Bangalore, Karnataka
June 3, 2010
June 5, 2010
Dear Mr. Joko (Pak Joko - Indonesia language)
I know your problem very well, it's happened a lot in our area due to bad material and treatment system, sometimes the oil quality also very low grade.
My team has successfully help our customers by using as follows:
1. Degreasing - 10 minutes (demulsifier type with oil separator unit)
2. Anodic Cleaning - 5 minute - 5 A/dm2 (Very high alkaline cleaner with descaler properties)
3. Pickling - less than 5 min due to heat treated steel/hi-carbon steel, HCl : 35%~50% by volume, plus Pickling Accelerator Additive+Pickling Inhibitor to prevent material to be attacked by Strong Acid
4. Anodic Cleaning - 5 minutes - 5 A/dm2 (same chemicals as no. 2)
5. Acid Dip - HCl 5% - 1 minute
6. Alkaline Dip - NaOH :5% - 1 minute
7. Alkaline Non-Cyanide Zinc
Please try, and let me know the result, Good Luck.
Very best regards,
Tony Chandra
- Jakarta, Indonesia
