Hard chrome plating chipped off
Q. Q.I'm from Bangalore and we do hard chrome plating for piston rods.
We are facing chip off issue at the chamfer edges.
Base material is C45.
Can you anybody please help to come out from this problem. Raham Thulla
Employee - Bangalore, India
December 30, 2019
A. Your fixturing is wrong.Consult somebody who is experienced in HARD CHROME plating.
Avinash Vidhate- Maharashtra, India
A. I think it's a problem with the pre-worked piece. It happens to us on stainless steel pistons when the seat for the chrome plating is not well radiated.
In rectification this problem is encountered.
- italia
August 31, 2022
Q. I have a problem with the trunion of Chromed part. The tip of the trunnion has been peeled off, more clearly when the tip of the chrome was polished to form a radius at the tip precisely at the end of the chamfer. Material is Stainless.
I have done several actions, but the results still exist, for example:
Modification to the masking equipment,
Controlling the rinsing solutions,
Changing the method of current flow,
Controlling the anode and cathode.
My Question is:
for hard chrome plating is there any method for checking against the surface which has the possibility of peeling, if any, whether the method should be used?
What exactly is causing the hard chrome peeling?
Quality Engineer - West Java, Bandung, Indonesia
May 21, 2010
A. I would call that "edge chipping". The first fix that I would try is to put a much larger radius on the corner lip of the part. - Navarre, Florida A. I believe that to get really good adhesion of hard chromium to stainless a Woods nickel strike is required. Nickel chloride 240 and HCl 250 mL/L, 3-10 A/dm2 (30-100 A/sq ft.) Don Baudrand Consultant - Poulsbo, Washington (Don is co-author of "Plating on Plastics" [on Amazon or AbeBooks affil links] and "Plating ABS Plastics" [on Amazon or eBay or AbeBooks affil links]) |
by Robert K. Guffie
(currently UTL on eBay)
by Weiner & Walmsley
** rarely available **
** rarely available ** or
by George Dubpernell"
A. Hi, Anders Sundman 4th Generation Surface Engineering Consultant - Arvika, Sweden Q. I appreciate your responses. - Bandung, West Java, Indonesia May 26, 2010 |
A. From what I see, I am of the view that the fault lies in post plating grinding operation; use specific grinding wheel with lots of coolant as there is a lot of localised heat that is generated when you grind, and lastly: Never start Grinding from the beginning of plating but plunge the wheel a few mm inside and take a cut inside out. Good luck.
Mahendra Gargatti- BELGAUM, KARNATAKA, India
Q. Hello Everyone.
We are into hard chrome plating of barrel bore of small arms. We are facing a problem of chip-off when the gun is fired. Can someone kindly suggest the cause of this and remedial measures that can be taken.
Small Arms Factory - kanpur, UP, India
July 20, 2017
? Hi cousin Sahil. I think you probably need to start by telling us whether the barrels are aluminum (what grade), stainless (what grade), or carbon steel (what grade). Thanks.
Chrome chipping in Rails of 3 piece Oil Ring
Q. I work in a firm where we manufacture piston rings. We are facing an issue of chrome chipping in Side Rails of 3 piece Oil rings. We assemble the rings in the form of mandrel. our bath is sulphate bath. We use ultrasonic and jet wash for initial cleaning and we also have a separate tank for etching.
Bath density - 18 Bé to 22 Bé
Current density - 4 ASI
Temp - 58-62 °C
Engineer - Chennai, India
October 25, 2017
