Stripping hard anodising without dimensional change?
Hello I need too remove hard anodising from a disc which is around 50 µm but the only problem is that it has a bore in the middle with close tolerance any other way without using caustic etch many thanks Phil
Phil Martin
employee - United Kingdom
May 19, 2010
Hi, Phil. A mixture of chromic and phosphoric acid will strip anodizing without attacking the underlying aluminum. If you use the term "chromic-phosphoric stripping" in our search engine you will find many detailed discussions. But whatever the thickness of the anodizing, that much will be gone after stripping.
May 20, 2010
