Simple test for galvanized metal
Is there an easy way I can test a piece of powder coated steel to check if it is actually galvanized under the paint? Thanks.
Byron Robinson
Manufacturing - Wayne, New Jersey
April 21, 2010
April 22, 2010
Hi, Byron. It is possible to do an XRF scan to look for the zinc, but I probably wouldn't call that idea easy.
Destructive but simple test:
Carefully grind or sand the paint off trying not to abrade the metal beneath, then apply a drop of diluted muriatic acid over the exposed metal. In a few seconds a galvanized surface will start gassing and bubbling until all the zinc is dissolved. A bare steel surface will not be affected.
Guillermo Marrufo
Monterrey, NL, Mexico
April 24, 2010
