Alternative to Electroless Nickel Plating
 April 21, 2010
We currently have a 100 kg pump body machined from a (carbon) steel casting. The media passing through the valve is drilling cuttings from oil exploration. The final stage of manufacture is for the part to have a 100 microns hi phos ENP coating to a tolerance of ±5 microns.
Is there a readily available alternative to ENP that would provide comparable wear resistance characteristics?
Geoff Hume
manufacturer - Stoke on Trent, England
Hi, Geoff. Although it's probably obvious to you, you haven't told us what property or characteristic of electroless nickel you find unsatisfying, so we have no way of proposing something that you might find more satisfying :-)
Chrome plating would provide equal or better abrasion resistance, but it is not as corrosion resistant as electroless nickel. It may be possible to heat treat, or even cryogenically treat the surface for greater abrasion resistance. Salt bath nitriding might be doable and would improve both the corrosion resistance and wear resistance compared to plain steel. PVD processes are probably not applicable because this is an internal surface. ENP is widely used in this sort of application because it is generally very well suited. Good luck.
April 21, 2010
First of two simultaneous responses -- April 22, 2010
HI Geoff Hume,
For your Application Nylon based Powder coating will help, but the disadvantage is,
1) you will not get the nickel colour
2) Thickness not able to control ± 5 microns
3) You have not mentioned anything about the oil temperature, this type of coating will not withstand approx. more than 110 C
Kannan Boopathi
- Salem, Tamil Nadu, India
Second of two simultaneous responses -- April 22, 2010
100 Kg pump body is fairly large and presumably has holes in it.
To obtain a tolerance of ±5 mu with any electroplating process would require extensive masking and auxiliary anodes - a highly skilled process for which you pay. Even then with chrome you would almost certainly require a grinding op to achieve the tolerance.
That is why EN is so widely used in the oil industry.
Why do you want to change?
If you feel the wear resistance offered by the electroless nickel coatings are not good enough, then try electroless composite coatings incorporated with SiC.
T.S.N. Sankara Narayanan
- Chennai, Tamilnadu, India
(ed.note Nov. 2017: The good doctor has a fascinating blog at https://advancementinscience.wordpress.com)
April 27, 2010
YOU CAN TRY ELECTROLESS NICKEL BORON OR ELECTROLESS NI WITH NANODIAMONDS
BOTH HAVE VERY HIGH HARDNESS AND WEAR RESISTANCE
Ricardo Burstein
Bnei Berak, Israel
May 1, 2010
