Contamination limits for Woods Nickel Strike
A. I would like to know if anyone has established metal contaminant limits for a typical woods nickel activating bath?
John Tinder
plating shop employee - Milwaukee, Wisconsin, USA
March 24, 2010
A. I will not comment on "metallic contaminants" but I will state that the statistically most frequent problem is that platers do not understand that leaving S-rounds soaking all weekend (when they should be using [and removing] Rolled Depolarized) increases the nickel metal content and changes the strike from an inefficient "strike" to an efficient plating solution that does not bond.
robert probert
probertbanner
March 25, 2010
Q. The main thing to watch in your Wood's bath is copper. You don't want more than 80 ppm or you will start to develop adhesion problems.
Jon Barrows
Jon Barrows, MSF, EHSSC
GOAD Company
Independence, Missouri
goadbanner4
March 25, 2010
Fe contamination in Woods Nickel
Q. We have been experiencing a low fail rate adhesion issue (blistering after 30 minute dwell at 300 °C) on S303 parts that are barrel plated through a Au/Ni process with Wood's strike. Our chemistry seems to be in spec with what everyone has recommended over the forum but we do have a significant level of Fe in the bath, at this point it is over 1000 ppm. Would codeposition of Fe in the Ni cause stress leading to adhesion problems? What are the standard levels of acceptability for Fe in Woods?
Tim M [last name deleted for privacy by Editor]
- Massachusetts, USA
November 15, 2018
November 2018
"Trouble in Your Tank: Handbook for Solving plating Problems"
by Larry Durney
durneyT
(currently UTL
on AbeBooks & eBay)
A. Hi Tim. I'm not aware of any textbook information on that subject, but 1000 ppm sounds like a huge amount of iron contamination even for standard nickel plating, let alone a Wood's nickel strike. I can't swear that iron contamination is the cause of your adhesion or stress problem, but I do note that in Durney's troubleshooting text "Trouble in Your Tank", right after "Don't Panic" and "Identify the Problem" is his third whole chapter entitled "Obey the Letter of the Law". 1000 ppm Fe is surely nowhere near right; don't talk yourself into accepting it :-)
It seems that there are two likely causes, operating with a partially anodic cycle (which is suggested in some text books, but which some knowledgable writers question), or parts falling off the rack and dissolving. Or is there another explanation for this high amount of iron?
pic of Ted Mooney
A. I do not think Fe contamination causes adhesion problems; iron causes roughness, maybe not enough Ni thickness, or current issue, or poor pre cleaning issue.
popat patel
Popatbhai B. Patel
January 10, 2019
A. The most common cause of adhesion failure with a nickel chloride strike is the the anodes have been left in and the metal has climbed to where the inefficient strike has converted to an efficient plating solution. do not use S-rounds, use Rolled Depolarized solid nickel bars and take out when not in use.
robert probert
probertbanner
January 11, 2019
A. What I have found that causes most issues with adhesion in the woods nickel strike is copper contamination, not iron. However iron is the bane of most plating baths
Thomas Swan
East Side Plating - Portland, Oregon, USA
January 12, 2019
