Lacquer yellowing
by Robert D. Friedel
or eBay or
Q. Hi all,
Have a problem with polyurethane coating which assumes a brown-yellow colour when undergoing a tropical test in contact with leather. Coating protects Brass zipper teeth.
The problem occurs even when coating is put over white carton.
Does anybody have any ideas ?.
Continuous Improvement - Varese, Lombardia, ITALY
January 8, 2010
Q. I've heard our lacquer supplier who said that yellowing might be due to the % of catalyst. Does anybody have any other suggestions?
Your advice is welcomed.
- Varese, Lombardia, Italy
January 20, 2010
A. Could it the tannin from the leather? However, it is more likely that the lacquer is not yellowing but the brass substrate being affected by UV light rays. Try to add some UV absorber to the lacquer if it does not have some already included.
Terry HicklingBirmingham, United Kingdom
January 22, 2010
A. You inform me that it yellows (private e-mail) without UV interference ... unless you keep it protected natural sunlight will yellow some resin systems. Try to purchase a lacquer based on an acrylic resin system ... if I remember I think paraloid acrylic resins dissolved in solvents would be the basis for a suitable varnish.
February 12, 2010
March 9, 2010
Dear Terry,
I thank you for your suggestions.
Do you know if any commercial product exists with the properties you mentioned ?
A. Try Paraloid B 44 acryl resin dissolved in toluene(you can use less toxic solvent/or solvent mixture too).7,5-10% must be ok.I think that Italian company CTS Srl. sells it(conservation of metals is one of applications).Baked epoxy based clearcoat(special coating for brass/aluminium hardware) can be very good too(Austrian producer is Lorenz Industrielacke, Purkersdorf).Hope it helps and good luck!
March 17, 2010
