Corrosion resistance of chrome plated 316 stainless steel
Our grinder salvaged an overground 316 stainless shaft by chrome plating to build up the thickness on a diameter and regrinding to size. Our customer wants to know if the resulting part has similar (or improved) corrosion resistant properties vs. 316 stainless before he will accept the part. Can you help?
Dave Wilkerson
Customer - Cedarburg, Wisconsin, USA
November 13, 2009
It will depend on the climate that it is exposed to. If the chrome job was well done and properly ground, I think that the plated one will be superior to the unplated one in most cases.
Hard chrome will exhibit equal or better corrosion resistance in virtually any environment.
November 24, 2009
Except chlorides Jeff, or am I wrong?
Best regards,
Guillermo Marrufo-Monterrey, Mexico
Guillermo Marrufo
Monterrey, NL, Mexico
