Which is a suitable process before painting
Which is a better process to do before stoving epoxy/ enamel painting - Zinc phosphating or Zinc plating- why?
Thangaraj Vagulabaranam
product designer - Chennai, TN, India
October 22, 2009
Hi, Thangaraj. Zinc phosphatizing is far more common. Zinc plating has the advantage that you have a true cathodic protection system under the paint to protect from rust in the event of a scratch or chip, but it's more expensive and probably somewhat less reliable in providing good adhesion.
October 22, 2009
Dear Sir,
You are right,
Zinc Phosphating will be best for this application.
Deep Mathpal
- Greater Noida, Uttar Pradesh, India
October 27, 2009
Dear Thangaraj,
Phosphating is the common [treatment] for before painting, if you doing the Zinc plating before painting, you will get better corrosion resistance. if, you are not having any problem in the salt spray go for phosphating
Kannan B
- Salem, Tamil Nadu, India
October 29, 2009
Hi Thangaraj
What is the material you are going to do painting, steel or cast iron etc?
Please explain your actual requirement on corrosion and adhesion for your parts.
If it is cast iron parts you can still have the choice of avoiding phosphating by replacing regular shot blasting as pretreatment process for your parts.
But make sure your corrosion and adhesion requirements are accomplished
Good luck
Vijendran Sudeendran
- Chennai, India
October 30, 2009
hi,
how would you rate (compare) zinc phosphating, iron phosphating and shot blasting on MS base surface on a 0-9 scale in terms of adhesion and corrosion resistance?
thanks,
Srujan Joshi
- Pune, Maharashtra, India
November 22, 2009
Hi, Srujan. You are asking for a quantitative answer to a question which I think only provides enough data for a qualitative answer, so I guess I'd answer: 9, 4.5, 0 :-)
November , 2009
