Passivation of Polished Aluminum
Q. I need polished aluminum sheet that will not oxidize and will maintain an emissivity of .05 over time. I believe passivation in nitric acid will do this but want to make sure I am going the right way and to find someone that can do this. Any suggestions are welcome.
Mark DiPietroDesign Engineer - Campbell, California
September 8, 2009
September 10, 2009
Aluminum How-To
"Chromating - Anodizing - Hardcoating" by Robert Probert You'll love this book. Finishing.com has sold 880 copies over the years without ever a single return request :-) Also available in Spanish A. Nitric acid passivation is a process used to remove free iron from Corrosion resistant steels (read stainless steel) and is an etchant, not a passivation process for aluminum. Metal Finishing - San Jose, California A. For high end material, I would look at bright dip and clear anodize and sealed with DI water. You might find a suitable clear coat for it also. James Watts- Navarre, Florida September 10, 2009 |
A. Dear sir.
best for aluminium is anodising only . you can choose green / blue/ or choice of your colour.after anodising it can be sealed by solutionsing at it will protect a corrosive resistance.
with warm regards,
- Banglore, India
September 14, 2009
Q. Alloy 1100-0 seems like it might be my best choice. It is resistant to corrosion and has very low emissivity. What would be issues with this?
Mark DiPietro [returning]- Campbell, California
September 15, 2009
A. This is the old problem of the term "passivation" used for multiple processes.
If the concern is surface contaminant iron turning to rust, then a stainless steel type passivation (nitric or citric based) is what will remove that iron for you.
If the concern is to protect the aluminum from something along the lines of chloride corrosion, some sort of coating or anodizing is probably best.
Of course normal oxidation on the surface is something you DO want, aluminum naturally forms an aluminum oxide layer.
Ray Kremer
Stellar Solutions, Inc.
McHenry, Illinois
September 17, 2009
Why does bare aluminum continue to corrode?
Q. Dear Sir or Madam, If aluminum naturally produces an aluminum oxide coat, why does it keep producing the white corrosion afterwards? How can I prevent for this to happen?
Leticia VargasAutomotive - Novi, Michigan, USA
October 2, 2018
October 2018
Treatment &
Finishing of
Aluminium and
Its Alloys"
by Wernick, Pinner
& Sheasby
or eBay or
A. Hi Leticia. This issue is easier to understand if we postpone the discussion of aluminum for a couple of sentences and think about steel first. We all know from a lifetime of experience that unprotected steel will soon start rusting and just keep rusting. The reason it keeps rusting is that the rust is loose, fluffy, and hygroscopic -- the rust contributes nothing at all towards sealing the underlying steel away from the environment. On the other hand if you paint or lacquer steel, it helps keep water and oxygen away from the underlying steel and it can slow the corrosion.
Now, back to aluminum. Aluminum is a very active metal that reacts instantly with oxygen to produce an aluminum oxide white rust. In an ideal situation that aluminum oxide would be tight, adherent, and waterproof and would shield the underlying aluminum from continuing corrosion much like a paint or lacquer would; in a less ideal situation the aluminum oxide would be porous and hygroscopic, and ineffective in shielding the underlying aluminum from the environment.
Anodizing is a process of very carefully engineering and controlling the formation of that aluminum oxide in order to make it tight, adherent, and waterproof. If we simply put bare aluminum out into the environment and let the oxide form as it will, what usually happens is, depending on the grade of aluminum, the localized corrosion forces, etc., ugly white corrosion and pitting build up. Aluminum needs to be protected from the environment with anodizing, or chromating, or chromating followed by painting or clearcoating. Good luck.
