Eliminate or trap off the Chloride from Sea water
Hi, I've a trouble to develop the procedure to make use of the Sea water, the Chloride create corrosion trouble to the steel. Then how can I get rid off this chemical from the Sea water? I know that the Silver ion can precipitate the chloride BUT it is very expensive and I don't know how to recover the Silver ion back to re-use again.
Mr. Prasit Sumanutvarapun
Engineer - Pathumthanee, Thailand
August 18, 2009
Hi, Prasit. I think you need to explain your situation before anyone can help you. Do you need one test tube full of water, or the continuous water supply for a major city? Reverse osmosis systems are used to make drinking water from sea water. Good luck.
August 18, 2009
Reverse osmosis or distillation are the two things you'll want to look at.
Robert H Kinner
- Toledo, Ohio
August 22, 2009
