Difference between clad and plated
August 4, 2009
Hi
I would like to know the difference between clad and plated.
Anneke
regulator - Johannesburg, Gauteng, South Africa
Hi, Anneke. Although it may depend a bit on the situation, "clad" generally means that sheets of the various metals were pressed together in an autoclave and then rolled down to size. The platinum on clad anodes is probably thicker than on electroplated anodes.
August 5, 2009
