Plating Tank - What kind of material can it be?
So, I have a project I'm working on, plating Copper to an Aluminum panel - there's already a question on the DIY nature of that here, so I won't bore you with that. However, I do have another question that's rather important, as it would determine my costs.
I've noticed online that there are a lot of polyethylene plastic tanks used for immersion - they're non volatile, and can withstand acidic solutions with no problem. I was wondering if either a glass or stainless steel tank would be just as useful for a slightly acidic solution. If not, what's the likely negative outcome from using a metal and/or glass immersion tank for electroplating?
Joe Tynan
Hobbyist - Seattle, Washington, USA
March 12, 2009
March 15, 2009
Hi, Joe. Although there are several different types of copper plating solution and they are very different from each other, a steel tank is inappropriate for any of them. Glass should be okay except in the unlikely event that you are using fluoborate-based copper plating solution; but glass can break, causing a pollution incident and a possible safety issue. Polyethylene is probably okay, but a fire hazard if you put an electric heater in it.
Thank you for the response! Fortunately, I do not plan on having a heater inside the bin.
Joe Tynan
March 27, 2009
It is safe to use a heater in a plastic tank if the heater is derated and has low level conductivity and thermal safety switches built into them. I would not say that this is totally true for quartz heaters, as I watched one blow the top off and melt the top lip of a poly tank. The thermal safety device was still in the solution.
Plating aluminium is not easy and needs a zincate treatment. This contains cyanide, so I would be very careful in doing it and make sure that you don't dump any of the zincate down the drain - you could end up in court
