Need Silver brightener / need formula
⇦ (tip: readers usually show little interest in abstract questions,
but your actual situation will usually bring responses)
RFQ: DEAR SIR,
WE WOULD LIKE TO HAVE INFORMATION ABOUT MANUFACTURES/TRADERS NAMES, ADD., FAX NO., E.MAIL NO., FROM ANY COUNTRY FOR SILVER PLATING BRIGHTENERS, SULPHONATION BASE. LIKE DICO GALVANOTECHNIC GMBH, W.C.HERAUS GMBH, DEGUSSA GALVENOTECHNIC GMBH AND MANY MORE IN GERMANY.
THANKS.
REGARDS.
- AHMEDABAD, GUJARAT/INDIA
A. Hi Janat,
We can't suggest brands or sources in this public forum ( huh? why?) but people can respond to you privately.
Not to be nosey, but you might get better response if you say why you want these names. If you want to buy silver brightener, people will be anxious to introduce themselves and tell you about their offerings! But if you're trying to sell chemicals to those silver brightener manufacturers, they're probably not very interested :-)
Q. Dear sir! I'm working on a research of silver brightener. Will you please provide me a detailed solution of silver brightener?
RAJ SHARMA- AGRA, U.P., INDIA
A. Modern brighteners are very proprietary and no one will give you that information. Old, less effective ones are found by doing research on old published papers and patents. Another clue, a brightener can vary from a tiny amount of mercury to an organic compound that I can neither spell nor pronounce. This will vary by the process that you are trying to brighten.
James Watts- Navarre, Florida
A. Production of a workable silver brightener will need a good set of references and a close access to a silver plating factory to test the product.
Asif Nurie [deceased] [deceased]
- New Delhi, India
Q. Dears ...
I ask you to help me please
I want to know what is the chemical formula or chemical components of silver brightener?
Please help me.
Yours,
- Beala, Egypt
A. Greetings From Lima Perú. The most used brightener of Silver plating, and very old, is carbon sulfur CS2, and is prepared in a dark glass bottle, adding to 1L of deionized water, 15 mL - 20 mL of carbon sulfur and 15 g of potassium cyanide KCN. Mix it strongly and hide it from light for 3 days, the top clear solution is used, adding 0.1 mL/L - 0.5 mL/L
Joe RoblesChemist - Lima, Perú
RFQ: Dear sir,
We are plating chemical trader & urgently requires silver plating brightener (black powder).
Do you suggest any company which manufactures or deals in this brightener?
thanks.
Dealer - Vatva, Gujarat, India
December 20, 2008
RFQ: Is there any pioneer here who can suggest me a c/o which deals/manufactures in Silver plating brightener (black powder).
Kishan Patelelectroplater - Rajkot, Gujarat, India
January 23, 2009
RFQ: Hello sir,
I have my own silver cyanide plating plant and most of the time when I did plating of my silver ornaments, it was not so bright.
I discussed with many people and we all came to the same conclusion that the brightener is not so good quality.
Therefore, I set up my own lab for making brightener but I didn't get the proper raw material for it, my friends said that in India most of the companies brought or import chemicals from Germany or US.
So sir, please suggest me the names of companies from which I am able to fulfill my requirements for the above situation.
thanking you.
Plating Shop employee - Mathura, U.P., INDIA
July 30, 2009
A. Dear Vivek,
Many people you discussed may not be having the right idea from where to get good Silver plating Brighteners.
Many world renowned companies have selling agents in India.You may have to look for them in Cities nearer to you like Agra, Delhi or even Mumbai.
Good luck
T.K. Mohan
