Steels specified for hot ferric chloride solutions
HI there, I am currently designing a digester and a concentrating pan for the manufacture of ferric chloride [on
Amazon (adv.)] solution using HCl and Pyrites cinder. What would be the best corrosion resistant stainless steel to specify for the:
1. Steam coil
2. The digester shell?
The temperatures go as far as 150 OC during digestion.
phosphate industry - Harare, Mashonaland, Zimbabwe
January 24, 2009
There is no stainless steel that will be resistant to ferric chloride [on eBay or Amazon (adv.)]. If you want it to be metallic chances are you will not be able to afford it. Consider plastics.
January 28, 2009
Not many plastics will withstand 150 °C. You may need to consider either ceramics or glass
