How to remove cured epoxy adhesive from stainless steel
March 14, 2022
Q. Please I am looking for a chemical that can be used to remove epoxy paint from large stainless steel floor.
Abayomi Adel- NY Netherlands
Q. I am trying to remove or strip cured epoxy from stainless steel surface. I used NMP to clean it. Epoxy was partially removed, but stainless steel was corroded too. Can you recommend me some approaches to remove cured epoxy from stainless steel surface
Zhenwei Houelectronics - Minneapolis, Minnesota
January 23, 2009
A. Hi Zhenwei. Please see letter 10780
-- I think you will find it to be the answer to your inquiry.
January 29, 2009
A. I just finished cleaning cured epoxy from an electric ducted fan with a Dremel
[on
Amazon (adv.)] and a wire brush bit.
The epoxy had dripped inside the fan unit and gotten on the fan blades and shroud freezing the unit.
Be very gentle and run the Dremel on its slowest speed.
- Kamloops, BC Canada
June 29, 2011
