A Good Copper Electroplating Solution for Science Project
I am conducting a science research project inquiring into the relationship between temperature and the amount of copper transferred during the electroplating process. I am in 10th grade Honors class and am looking for a formula for a solution that I can use that does not contain concentrated sulfuric acid. any suggestions would be much appreciated.
John S.
student - Hershey, Pennsylvania, USA
September 23, 2008
September 24, 2008
Hi, John. You can use copper sulphate [on eBay or Amazon (adv.)]without any sulfuric acid if you wish. It's not ideal, but it will work. See if a local library can get you a copy of the Metal Finishing Guidebook or the Electroplating Engineering Handbook [on AbeBooks or eBay or Amazon (adv.)] for full details about copper plating. Good luck.
hello, this is a follow-up inquiry. I am in 10th grade honors chemistry class and am doing a science research project. I am testing so see whether temperature affects the amount of copper transferred onto brass cathode. I am setting up my project and am wondering how I could control a constant test group and a higher but sustained temperature. Also, how much can I change the temperature to ensure I am not doing anything unsafe by heating acids.
John S
September 26, 2008
October 1, 2008
Hi, John. You could use an aquarium heater, or pour hot water around your experiment dish in a double-boiler effect. But using ice in the double-boiler may be an easier way to try another temperature.
October 15, 2008
hello,
I am struggling with my science research project. What could I use as a base metal to plate copper onto if I am using an acid copper solution. My teacher specified I couldn't use brass. I have found conflicting evidence about whether I can use iron, tin, or aluminum. Help would be greatly appreciated.
thank you
John S
October 16, 2008
Electroplate onto a quarter, John. It's a cupro-nickel alloy. You cannot do scientific work electroplating onto iron, tin, or aluminum because copper will spontaneously deposit onto them, due to their lower nobility, without any electricity applied. Good luck.
October 20, 2008
Hi,
After taking much info from this site, thought it would be time to give some back. Just tried copper immersion plating on blank steel with household chemicals. The best recipe follows.
Source steel: 4" round disks, drum-deburred, rinsed at the factory. They seem to be oil-free, and corrode quickly if touched by bare fingers. Nails and other hardware which usually rusts works well, too.
Solution: table vinegar [in bulk on eBay or Amazon (adv.)] (4% acetic acid in water?), the cheapest (and the cleanest) brand - no flavorings, just water and acetic acid. Costs 40 eurocent per 1.5 liters here in Lidl :) Copper wire from a multi-strand cable. Strip isolation, disperse the braid with your fingers and throw it in acid. Then add a little bit of medicinal (3%) hydrogen peroxide [on eBay or Amazon (adv.)] - this will oxidize copper and really speed up the dissolution. You may heat up your solution to some 50-60'C, but even without heating, if you add peroxide, you will see blue tint develop in an hour or two. You may add some table salt, although it seemed to me copper sticks to steel better without.
Alternative solution: 50mM (6gr/liter) CuSO4 in vinegar. Advantage: turns blue instantly :) so you can plate right away, but you will need copper sulphate [on eBay or Amazon (adv.)] (which is somewhat poisonous!)
IMPORTANT: when buying vinegar, also buy a steel pan-scraping sponge. When you are done plating, drop the sponge into your solution overnight to remove Cu2+ ions (very bad for the environment) from the vinegar before you dispose of it. Afterwards, you can pour the vinegar down the drain (and trash the sponge).
Plating: 30-60sec will give you a dark copper color finish. Rinse well in distilled water (if available), and DRY QUICKLY! (with a tissue) Your iron is not 100% covered with copper, so it will continue to corrode if wet. You can coat the final product with hairspray to keep it nice for longer.
Extra trick: we first let the kids draw some stuff on the steel with permanent markers which are invisible in daylight and fluoresce under UV (blacklight). Then in daylight they saw their drawing "re-appear" in the copper/vinegar plating bath.
SurfCat at Leiden
- Leiden, Holland
