Need Zinc-Nickel Plating Sources
RFQ: Need to locate a source for zinc nickel plate AMS2417, type 2, NADCAP approved ASAP.
Thank You!
Mark P [last name deleted for privacy by Editor]
Ed. note: The RFQs on this page are all expired. Please see our "Hotline Public Forum" page for active, current RFQs.
RFQ: I am looking for companies who do Zinc-Nickel plating.I have had problems finding a company to do this for me because of the part's dimensions.
The part is semi circular with a maximum diameter of 7.4 feet and a depth of 1.5 feet. If anyone knows who can coat a part with these dimensions, please contact me. Thank you.
Oladapo F [last name deleted for privacy by Editor]
- Tujunga, California, USA
Oladapo, One option you can check out is Brush Plating. This process uses hand held electrodes to deposit the material. Because it doesn't use tanks it can plate large components.
David Crocker
- Valencia, California
RFQ: Is there anyone out there that knows of a plating company in Canada (preferably in Ontario) that does a mixture of Zinc and Nickel plating. It is ford spec WSA-M1P87-A1. Anyone I have contacted says they can do one or the other but not both.
Dan V [last name deleted for privacy by Editor]
- Burlington, Ontario, Canada
RFQ: We are a clutch & brake manufacturer for the industrial, aerospace and medical industries located in N.J. We need a plating house that will plate our low carbon steel parts with Zinc Nickel per AMS2417. Please provide plater names and locations.
Rick R [last name deleted for privacy by Editor]
- Springfield, New Jersey, U.S.A.
RFQ: I am looking for a company that can provide Zinc Nickel Plating - black. The parts must be plated on a rack. There will be 300,000 pieces approx. per year. If you currently have this process, please email me and I will forward print for quote.
Thank-you!
Denise B [last name deleted for privacy by Editor]
- Milwaukee, Wisconsin, USA
RFQ: I have a customer looking to have a small lot of fasteners plated to this spec:
ALKALINE ZINC-NICKEL
ASTM B841
CLASS 1, TYPE 3, GRADE 3
TOTAL WEIGHT IS ABOUT 5 TO 7 LBS
JEFF S [last name deleted for privacy by Editor]
fastener distributor - HUNTSVILLE, Alabama
RFQ: I am looking for a plater that can do Zinc Nickel & clear chromate with sealant.
Jim A [last name deleted for privacy by Editor]
screw machine shop - Hanover Park, Illinois, USA
RFQ: I need a supplier that can do zinc-nickel coating. I have been looking but there is no one in Australia that can do it. Do you know anyone?
Ozren Zrnic
Applications engineer - Sydney, NSW, Australia
"Theory & Practice of Metal Electrodeposition"
RFQ: I need to have small steel parts (fixture/fasteners/clips) plated with zinc-nickel coating. The parts are made of high strength steel grade (HRc>35). I am looking for plating vendors in Ohio and surrounding states who can plate zinc-nickel coating on such parts.
Raj Singh
small parts fabricator - Cleveland, Ohio, USA
RFQ: I am looking for a quote on Zi-Nickel with Trivalent Chromate sealer that give protection to red rust 720 hours.
I have a steel 12L14 knurled ring that weighs 15#/M that we would like a barrel plate; quote on lots 10M and 15M.
Mike R [last name deleted for privacy by Editor]
Screw Machine Job shop - Saint Louis, Missouri, USA
RFQ: Screw machine job shop looking for supplier of electrodeposited alkaline zinc-nickel plating (per ASTM B841 class 1 type b grade 3) approx. 200 pieces 1/2 dia. 2" long 12L14 steel approx .25 pounds
Fritz S [last name deleted for privacy by Editor]
buyer ,production mgr - Cincinnati, Ohio
RFQ: Need ZNIDN3P & ZNIDN3L Zinc-Nickel Plating Service
Paresh Sheth
manufacturer of fasteners - Bangalore, Karnataka, India
March 25, 2009
RFQ: Hello, do you have any information about companies that supply Nickel Zinc Trivalent, or any brand of this kind of finishing? Thanks a lot. Laila
LAILA MARZALL
- SANTA MARIA, RS, BRAZIL
February 8, 2012
Hi, Laila. Please try our Jobshops Directory, or do your best to post the details of your needs -- some shops serve consumers whereas others only serve industrial needs; some only offer barrel plating whereas you may need rack plating; some offer only prototyping and others only high volume plating. Thanks!
February 10, 2012
