Shiny gold tone electric fixtures are outdated
I have several shiny gold toned electric sconces (circa 1998) that I would love to refinish with an aged pewter look. Do I need to remove the gold look with ammonia [on eBay or Amazon (adv.)] or other and start from scratch? Any process or pro product to recommend?
Gail Coleman
remodeler, homeowner - Fort Worth, Texas
September 7, 2008
Hi, Gail. Inexpensive sconces are probably not brass -- they could be anything from brass plated to nickel plated with a brass toned lacquer. Trying to figure out how to chemically react some unknown surface to make it look like some other metal will be an exercise in futility like trying to bake a cake from some unknown white powder found in the basement (it will come out very different depending on whether the powder is flour, confectioner sugar, plaster of paris, or baking soda). There are lots of fancy spray paints these days, including pewter colored, and that's the only way to go short of sending the sconces to a plating shop. Before painting, wash them with acetone [on eBay or Amazon (adv.)] (careful, it's flammable), which will remove any lacquer as well as most oils. Then prime with a self-etching primer [on eBay or Amazon (adv.)] Good luck.
September 11, 2008
Thanks so much, Ted! Sounds like a little trial and error is in order. If I take them to a plating shop, can they determine what the metal is?
Gail Coleman [returning]
September 12, 2008
Yes, Gail, they can. You can do some preliminary figuring if you wish. Steel is magnetic, neither real brass or anything else it might be is strongly attracted to a magnet. Aluminum is much lighter than other metals. You may be able to scratch the back of the sconce and learn something about what it's made of. Good luck.
September 14, 2008
Ted, you have been MOST helpful.I truly appreciate your kindness. Thanks so much!
September 18, 2008
We have a beautiful home but have dated gold tone fixtures throughout. We would like to know if it is possible to paint them or have them painted . If the cost to have them painted is too much it may exceed the cost of just having to replace them. I would love to try and do the work ourselves but need to know the correct procedures in order to assure a good outcome. Please help?!
Deanne Howard
- Surprise, Arizona
July 15, 2009
Self Etching Primer
on
Hi, Deanne. If they are brass, you must start with an 'etch primer'; regular paint will not stick to brass.
July 16, 2009
