-----sulfuric acid line problem
September 10, 2008
dear sir,
I'm working in a waste water treatment company.
I give dosing sulfuric acid (98%to 95%) with water to waste water in the resin filter through pipeline, My problem is sulfuric acid with water passing pipeline got damage, I used following materials for pipeline SS, MS, CPVC, UPVC, PVC. processing temperature around 99'c, working pressure .4 kg
my question is which materials I use for solve the above problem
please give suggestion I expect your valuable replay
thanking you,
with regards,
RAVIKUMAR
plant operator - Tamil Nadu, India
