-----Anti corrosion coating types for oil and gas pipes, casings of stainless or carbon steel
September 10, 2008
Dear All,
Oil & gas pipes ,tubes ,casing stainless or carbon steel anti corrosion coating types is needed because I faced some problem with some countries (like china) does not use the standards coating common codes, please give me a table with types descriptions ,codes, with estimated cost per meter and per ton for each size for stainless or carbon steel
Best Regards,
projects CPL coordinator - Cairo, Egypt
