49877
THE BEST SULPHURIC ACID PIPELINE MATERIAL
September 1, 2008
I AM TRYING TO FIND THE BEST MATERIAL USED FOR THE
TRANSPORTATION OF 92 TO 96% H2SO4 THROUGH A 14-INCH
PIPELINE, 20 KGF/CM2, AMBIENT TEMPERATURE (MAX 60 DEGR. C)
WHERE 7 KM OF IT RUN UNDERGROUND AND 2 KM AERIAL IN A MARINE
ATMOSPHERE. IT IS IMPORTANT TO KNOW IF SUCH INSTALLATION
EXISTS AND, IF THERE IS ONE, WHERE IT IS LOCATED.
ULISSES AMADO
Pipeline Engineer - RIO DE JANEIRO, RIO DE JANEIRO,
BRAZIL
Apply for a FREE subscription
to:
September 7, 2008
Hi Ulisses,
My preference would be towards a PVC dual laminate material. Why dual
laminate? Because the fibreglass would add strength to the PVC.
Cheers
Freeman Newton
- White Rock, B.C. Canada
September 10, 2008
Dear Freeman,
Thanks for your suggestion, but in this case the use of PVC
(polivinyl chloride) is not available. As I mentioned before in my
question, the pipeline will be constructed under the ASME code B31.4
(Pipeline Transportation Systems for Liquid Hydrocarbons and other
Liquids). We are thinking of using carbon steel API 5L Gr. B
specification and I would like to know about any experience regarding
corrosion on this material (liquid velocity 1.8 ft/s).
Ulisses Amado
- Rio de Janeiro, RJ, Brazil
September 17, 2008
Hi again Ulisses
You say that PVC is not available .. that I sure DON'T believe.
My background is mainly in plastics and were you to use PVC, then
cemented joints must NEVER be backswelded immediately but after min
24 hours.
Re steel ... well, that would be OK UNLESS air got at it
because steel is OK for conc.sulphuric BUT with air ingress you'd
dilute the sulphuric and get immediate corrosion due to that acid's
absorption of moisture from the air.
Freeman Newton
