49861
Is there a common method for hanging parts
to reduce shadowing? [Texas]
September 2, 2008
I am designing a decorative metal faceplate that is done in Chrome
and Nickel plating.
The front of the faceplate MUST remain perfect, but we are getting
shadowing from the finishing company using a corner of the faceplate
opening to hang the part.
The faceplate is milled on a X,Y CNC.
Is there a common feature that I can design into the part that would
allow the finishing company to hang the parts without touching the
front of the part?
My first thoughts are a undercut loop that would allow the finisher
to hook onto but this increases the cost of the milling.
Joshua D
Product Designer - Austin, TX, USA
September 2, 2008
Hi, Joshua. Not to quibble about words, but while you can "hang"
parts for zinc plating, you must "lock" them in place for
nickel-chrome plating because a current interuption will ruin them,
so you can't rely on gravity. So you need some feature on the back
that is grippable in some fashion or other.
You could meet with a rack manufacturer, who would probably love
the opportunity to work out a good racking arrangement and then use
the opportunity to force himself upon the plating shop :-)
finishing.com
Brick, New Jersey
