49852
7-tank phosphatization yields rusty,
patchy, yellowish work
September 1, 2008
Dear Sir,
We have powder coating plant, we are preparing surface prior to
coating i.e. phosphating, we are using seven tank process for it.We
are coating, HRC CRC hot rolled angle etc.our problem is that we are
not getting proper finish after phosphating.some rust & white ,
yellow patches are coming after phosphating.we are using phosphorus
base chemical. pls. suggest us proper method.
regard
Pravin Kulkarni
- Nashik, India
September 2, 2008
Hi, Nashik. This is an awfully broad question! When you ask for
"the proper method", whole books are written to explain what the
proper method is. Have you been successfully phosphating all along
and this is a new problem that has suddenly cropped up, or have you
never successfully phosphated yet? Thanks.
finishing.com
Brick, New Jersey
September 2, 2008
The proper place to start is with your vendor. If you are using a
home brew, no one can help you.
