Soldering of galvanized iron wire
Soldering hot dip galvanized iron wire with 60/40 tin /lead solder while using hydrochloric acid+zinc chloride+ammonium chloride as flux gives excellent results,but when the same process is applied to electro-galvanized wire,it repels the solder.What changes are suggested in solder or flux to accomplish the task ?
Varun Kumar
supplier - Mumbai, India
August 30, 2008
