49805
Sodium chloride piping
[Philippines]
August 27, 2008
Our company is a general contractor here in the Philippines...it
is our first time to encounter a sodium chloride piping.our costumer
required us to use PTFE pipes,but we dont have these kind of pipes
here in the philippines.i'm thinking of using substitute pipes if
possible.
1. can we use SS pipe as substitute for the PTFE pipe?
2. can we use PVC pipe as substitute for the PTFE pipe?
Ruben Lacsamana
ENGINEER - Las Piñas,Manila,Philippines
September 11, 2008
We have been using HDPE tanks and pipes for brine solution
(saturated NaCl solution) for water softening application.
uPVC / cPVC may be used. Avoid SS. Other options can be MS with
rubber or FRP lining.
Check out which one is readily available at your place and what best
fits your budget.
Sachin
Sachin Vaidya
- Vadodara, Gujarat, India
