49785
Can we specify Phosphate Texture?
August 26, 2008
Is there such a thing as "smooth" vs. "rough" phosphate? We have a phosphated part that is pushed into anther part. The "rough" finish increases the pushin force.
Dale Fedewa
Project Eng. - Manufacturing - Grand Rapids, MI, USA
August 28, 2008
Yes, you can by asking for a thinner coat.
A better way is to chose your type of phosphate.
Manganese is very coarse and rough, but is wonderful for break in and holding lubricants.
Zinc phosphate is finer, but if parameters are not closely controlled can get to be very needle like. My preference is a calcium modified zinc phosphate. It is quite uniform and smooth. Thickness is easy to control and can be quite heavy on a grit blasted surface vs a pickled surface.
Iron phosphate has virtually no corrosion protection and is mainly for paint adhesion.
Cost may be a factor as well as your desired use.
List of Directories
Link to Del.icio.us button Save This Page (why?)    -    Home    -    ©1995-2008 finishing.com
