![]() (Cycles thru suppliers) |
Passivation with phosphoric acid [India]August 26, 2008 For how much time SS should be dipped in phosphoric acid for
complete removal of rust? Deepak Kamble
August 27, 2008 Hi, Deepak. I have not heard of phosphoric acid for rust removal. Phosphoric acid will convert red rust to black rust, but I do not believe it will dissolve iron, which is necessary for passivation. The two common acids for this are nitric and citric. See ASTM A-967 [link is to spec at TechStreet] Regards,
September 8, 2008 Deepak,
Save
