Hot dip galvanising of S.G. iron products
     In hot dip galvanizing the components to be galvanized are dipped into a kettle of molten zinc (after cleaning and fluxing). The zinc partially alloys with the steel or iron and partially adheres as a coating which hardens as the component is withdrawn and cools.
     S.G. iron means spherical graphite iron (ductile iron), a compositional modification to cast iron rendering it more ductile and more corrosion resistant.      Read on, join in ...
Q. Dear Sir,
We are facing very big problems in hot dip galvanising of S.G. iron products.
When we try to dip it into the acid bath zinc doesn't adhere to the surface uniformly, meaning that zinc gets deposited on the surface as patches. There are many bare parts.
What could be be the reason for this and the appropriate solution?
Please guide
Thanks in advance.
Manjeet singh
plating shop employee - India
August 23, 2008
Hydrofluoric acid burns
left and right hands, two views, burned index fingers
Never use HF anywhere unless trained!
If you do, you MUST have the antidote gel on hand for instant use!
Calcium Gluconate
for HF acid burns
calcium_gluconate
A. Sir,
I had to "look-up" S G steel on the internet and it seems to be a type of cast iron. About 30 years ago I tried to clean castings using HCl and H2SO4 with little success. Then I tried with HF (hydrofluoric acid) and immediately the sand was removed and deposited on the bottom of the beaker. HF is extremely dangerous and I knew a guy who died from inhaling HF fumes. The glass "face" of his wristwatch was etched.
Some galvanizers use sand or grit blasting to clean castings, however too much blasting can break through the "shell" of the castings into graphite (carbon) rich areas and then the castings will not galvanize.
It is also possible that your flux solution is bad. You did not mention if you are using "wet" or "dry" galvanizing.
Dr. Thomas H. Cook
Q. I don't know about wet or dry hot dip galvanising. It is being done in a zinc bath at a temp of 550 °C. Can you explain this point?
The problem we are facing is that after taking out the product from the bath on some regions of the product sand comes over and no zinc is deposited on the surface. So a part of the product if left bare.
What can be done?
Manjeet singh [returning]
- India
SUGGESTED GALVANIZING BOOKS
for Engineers, Shops, Specifiers
galv_structures2016
"Hot Dip Galvanizing of Steel Structures" by Kuklik & Kudlacek (2016)
galv_hot_dip_handbook2011
"Handbook of Hot Dip Galvanization" by Maass & Peissker (2011)
galv_and_concrete2004
"Galvanized Steel Reinforcement in Concrete" by Stephen Yeomans (2004)
galv_practice_hornsby1995
"Hot Dip Galvanizing -- A Guide to Process Selection & Galvanizing Practice" by M. J. Hornsby (1995)
"Faults in Hot-Dip Galvanizing" by Dietrich Horstmann (in English, French & German)
avail from Amazon
"User's Guide to Hot Dip Galvanizing for Corrosion Protection in Atmospheric Service" by NACE (1997 only rarely avail.)
A. Sir:
"Wet" kettle galvanizing uses a top flux which is molten ammonium chloride/zinc chloride floating on the molten zinc. The usual color of this molten floating flux is black and it is smoking continuously. The items being galvanized pass through this molten flux, held in the zinc until "cooked out," and then withdrawn through molten zinc after the molten flux is skimmed to one side.
In "dry" kettle galvanizing the items being galvanized are put into a water solution of ammonium chloride/zinc chloride (best if this solution is hot at 70 °C) and then immersed directly into the bare molten zinc, cooked out, skimmed, and withdrawn from the zinc.
550 °C is much too hot for normal galvanizing. The usual temperature is around 450 °C.
The presence of sand (from the sand casting process) seems to be the problem. You must sand or grit blast off this sand (from casting) or use HF or sodium bifluoride in HCl or H2SO4. Remember HF or the bifluoride is extremely dangerous. HF vapor quickly destroys lung tissue causing death.
What is the density (baumé) of your flux solution (in water)? Or do you even use an ammonium chloride/zinc chloride flux solution?
In the USA most galvanizers are "dry" kettle. For your product a "wet" kettle may be more appropriate, and likely would produce an acceptable product.
Dr. Thomas H. Cook
A. Hello Manjeet,
I hope the temperature you quoted was an error - perhaps you meant to type 450 °C, not 550.
If you have sand on the surface of the SG castings, then you must have the foundry shot-blast or grit-blast them properly before you try to galvanize them. You must have a clean metal surface.
In reality, there should not be any moulding sand adhering to the castings. This alloy is cast at 1400-1450 °C which is a low temperature for ferrous alloys, and there is no problem having moulding sand which is quite resistant to the alloy at that temperature.
But it is a sad fact that some foundries do not control the quality of their moulding sand properly, in which case some sand may be fused onto the surface of the casting and have to be removed by grinding because shot- or grit-blasting is not strong enough to clean the surface.
Bill Reynolds
Bill Reynolds [deceased]
Q. Dear Sirs,
Thank you for your responses. If HF is that dangerous we can't use it as it could cause a great problem if some one dies of that.
We have got a sample ready after reading your suggestions. My customer is demanding 700 hours salt spray on that s.g iron product.
I think I have three options
1. Hot - Dip galvanising
2. Zn-Ni plating with passivation
3. Spraying with Magni coatings.
Which one do you suggest to be most economical?
- India
A. Hi, Manjeet. A principle reason for choosing S.G. iron is its inherent corrosion resistance. Maybe it doesn't need coating  🙂
Electroplating is more economical than dip-spin coating and much more economical than galvanizing, but 700 hours salt spray is a lot for metallic coatings on castings! It can be difficult to electroplate castings; you probably must use an acid-based zinc-nickel rather than an alkaline one.
Salt spray testing of galvanized coatings is foolish. Although post-dip galvanizing easily outlasts any other coating on steel in most environments -- lasting 50, 75, even a hundred years -- the way it manages this is through a very slow reaction with the carbon dioxide in the atmosphere over months, years, and decades, forming a glassy and corrosion resistant zinc carbonate skin. Regards,
